BROWNDOG
While moving our shop recently we disconnected all of the hardware, drove it a mile up the road and set it back up in the new location. Now our Ioline Classic Cutter will no longer communicate with the computer running Flexi-Sign 7.6. When you turn on the cutter and move the blade into place everything seems fine. It's when you hit start point (and the LED is supposed to turn green) that we find the problem. The LED is blinking, alternating between red and green. It will move when you select "test print" in the Production Manager set-up, so I believe the port is correct.
The manual says its a syntax error and the wrong driver may be selected. I've tried changing settings but cannot find anywhere to select a driver.
The plotter will behave in this manner even when Flexi is closed. Can anybody please tell me how to fix this problem or even what caused it? It's connected to the same computer in the same manner. Nothing has been altered except the location.
