Goatshaver
Came back after a couple of days laminated a few sheets and started cutting with the barcode like I normally do and my cutting was way off. Seemed to be about 1/16" off in some places, near the center of the sheet. The outer two edges were fine. I noticed as the moved to the cuts near the middle of the sheet they became more off. This happened to a couple sheets, and it was spitting out the sheets when it went to look for the next opos mark or it would spit them out during loading. I did a factory reset, calibrated my opos and tried another cut and got the same result, actually it was even worse. One sheet came out fine, then the next would be way off.
Never had this happen before so I'm not really sure whats going on. If something went haywire in my cutter or there is something else going on.
I attached a couple photos of one 8.38" sheet the difference between the top and the bottom of it and how off the cuts are.
