Is this a good deal?
Discussion in 'Miscellaneous Plotters' started by Tony Vega, Jul 6, 2005.
  1. Tony Vega
    Tony Vega New Member
    11
    I've been offered a 30" Ioline Studio 8 cutter fo $500. It looks and works great as I have seen it first hand. My question, is this a good deal and what software would be recomended that wont break the bank. Im only using this machine for small general lettering and our Stika just wont get the job done so its time for an upgrade. It comes with an older version of Casmate but I dont know which version or if it is still has a valid key. It's this or a Summagrahics D60 SE which I know will cost alot more in the long run once I add software. Thanks for the help from a noobie.
  2. Bill Preston
    Bill Preston Member
    108
    On the face of it, it sounds like a pretty good deal.
    I have been using an Ioline Classic 24 inch for over 9 years, and it has never let me down.
    If this is a fairly late model it may be such a thing as that it will cut from Corel directly. Mine will not, at least not without a bridge program.
    My own software is Signlab 5. Good program, but it is said that it is no longer supported.
    Good luck, whatever you decide.
    bill preston
  3. Tony Vega
    11
    Thank you Bill for your response. I see replacement blades for sale all over the web but havent been able to find sources for other replacement parts such as cutting strips. Any suggestions?
  4. Bill Preston
    Bill Preston Member
    108
    Tony, most any sign supplier should be able to get the cutting strips---also known as platen tape, or pincushion tape. You should also be able to get it direct from Ioline. The roll has enough to do my 24 incher, about two times with a little left over.
    Replacement parts I am not so sure about a source---so far, I haven't needed any.
    bill preston
