Issue with SummaCut D75
Discussion in 'Summa' started by Gateway, Jan 15, 2008.
  1. Gateway
    Gateway New Member
    1
    I'm having an issue with the SummaCut D75 I purchased
    last month. Its actually quite frustrating...
    Once I've loaded the media, I get an error message on the cutters LCD
    screen that says "Right pinch roller is not set properly above a sleeve!
    Raise the pinch rollers and set them correctly."
    This would seem like an easy fix, however the problem is the fact that the
    pinch rollers are both set properly above a sleeve.
    Any tips or what I need to do to fix this?
  2. markyeoman
    markyeoman New Member
    8
    Call
    Call Summa Tech Support 800 323 9766
    Mark
  3. JAMEY
    JAMEY Member
    346
    Sep 8, 2007
    New York
    Try moving the vinyl over to the right to cover the sensors.
  4. Jim Doggett
    Jim Doggett Very Active Member
    1,304
    1
    Hi,
    Jim, from SignWarehouse here (former Summarian). If it's pilot error, make sure the pinch roller is in the sweet spot. You can feel it click into place, if you move it slowly/gently. If it's an equipment error, something is haywire with the sensor. I'd advise you exercise the 90-day free replacement clause in the warranty.
    Best,
    Jim Doggett
  5. PGSigns
    PGSigns Active Member
    560
    On my Summa if the pinch roller is not in the what jim calls the sweet spot (a small hole drilled in the rail) I will get an error. Call them on Monday thier tech guys are very good.
    Jimmy
