Issues with transfering files to versaworks
Discussion in 'Roland' started by Turbophein, Apr 26, 2011.
  1. Turbophein
    Turbophein Member
    154
    I have the following:
    Roland SP300v running latest version of Versaworks
    Adobe Illustrator 9.0
    Adobe Master Collection CS3
    Adobe Photoshop CS3
    Flexisign pro 8.1
    every time i make a file and try to transfer it to versaworks it throws a error, not a readable file. i use .psd .png .tiff .ai .eps none of them work. if i save to jpeg it will transfer but the image turns to crap. i can also convert to pdf which works bit also ruins the image.
    i printed my first full size mx shroud today after converting it to .pdf it printed like crap around the edges of everything and i could not get the cut lines to show up.
    any help would be appreciated.
    thanks
  2. Gabriel
    Gabriel Member
    275
    Hi
    "File is corrupt"?
    If this is the message, you should try to reinstall versa works.
    Hope that helps!
  3. txsurfer
    txsurfer Member
    284
    Oct 29, 2005
    Texas
    we print all our files pdf
  4. Gabriel
    Gabriel Member
    275
    What rip/print software do you use? If you use versa works, i think that reinstalling it, will solve the problem.
  5. Turbophein
    Turbophein Member
    154
    i don't actually have the physical versaworks software, i bought my printer used, no software and i had a roland tech come out and install versaworks and set up the printer.
    out of all my editng/sign software, i really like using adobe fireworks. which is a .png file. i think once i convert over to .pdf i am losing the quality. i am also not sure if fireworks is supporting the mx template cut lines???
    anyone have a link to something like versaworks for dummies?
  6. Roland
    Roland New Member
    23
    There is a web site with short movies and all kind of examples myversacamm.com. Also, you can find some interesting short movies on Youtube.
    Good luck!
  7. Antonyu
    Antonyu New Member
    17
    Make shure that your VersaWorks version is 4.2.1
    If not, I would advise you to update it by closing VersaWorks and clicking on "Online Update" that it can be found in Start->Roland VersaWorks
    If it does not work take a look at 8080 TCP port on your firewall
    I dont have a SP300, but its best to check its firmware and update it accordingly.
    Also, are you sending the file by the windows driver RolandVW or are you opening it on Queue A/B in VersaWorks?
    For printing and working image files NEVER use Wi-Fi... even N 300mbps is not good enough.
    Hope this helps.
  8. MikeSTK
    MikeSTK Dawns Vinyl Designs
    157
    Feb 23, 2011
    Weatherly, Pa
    We had a bug at one point. When we called in the first thing they had us do was Programs>Verssaworks>Initialize Application
    I am not well versed but maybe this Initialize post will prompt someone more knowledgable to respond.
    Hope it helps.
  9. Turbophein
    Turbophein Member
    154
    i design my files at home on my laptop and bring them to my garage to print via usb memory stick. a lexar 16gb HD card that i use with my GoPro HD camera.
    the only thing i can think of is that my garage computer does not have any of the design software, just versaworks. i can't transfer the files to the cpu because it doesn't support those files but i figured i could drag them from the memory stick right to versaworks, which works if i convert to .pdf
    also i have no internet at my garage for the moment, i can however bring the cpu home if need be.
    i am pretty sure it is the latest version of versaworks but i will contact him and ask.
    thanks for the replies!
  10. Turbophein
    Turbophein Member
    154
    ok so i figured my file transfer problem out, i downloaded corel draw x5, that loads up just fine.
