Jeti 3150 Low Vac problem
cwb143
Got a new problem fellas. When the machine is off. The ink drops through the heads over night. But while its running its just fine. Any ideas what would cause this. Thanks!
RycckG
We had same problems. Batteries were not taking charge. If you leave power on overnight it will be fine until you get the charging system or batteries corrected.
cwb143
Looking at the batteries today. Is there any special way to replace these two? And is this a battery I can locate anywhere?
Typestries
My alarm guy had the same batteries in stock. $25 each. Quick change out and you should be back in business.
