Jexar 10oz Water Fast Scrim Banner with HP5500ps UV Ink
Discussion in 'Materials' started by BMurphy688, Nov 17, 2010.
  1. BMurphy688
    BMurphy688 Member
    43
    Hi all,
    I printed a banner the other day on my hp5500ps with uv ink on said product, jexar 10oz water fast scrim vinyl banner from fellers... Well, a little drizzle/rain hit the sign and ran.... As the banner is only going to be up for about a month, i didn't laminate.
    Called fellers, they sent replacement roll, and still having same problem. I have not changed inks or anything on printer in quite some time and had no problems with other substrates....
    Anyone have an idea?
    Thanks.
    Murph
  2. Brandon708
    Brandon708 Very Active Member
    1,128
    48
    48
    Sep 22, 2009
    Orland Park, IL
    everything that is printed with the 5500 that is used outdoors needs to be laminated.
  3. BMurphy688
    BMurphy688 Member
    43
    I had a banner outside my shop for well over a year non laminated without any degregation to the print... the wind finally tore the substrate, cheap material...
  4. Brandon708
    1,128
    48
    48
    Sep 22, 2009
    Orland Park, IL
    We use the Jexar banner material and never had a problem with it. We always laminate it though. If we didn't laminate it it would get dirty.
  5. BMurphy688
    BMurphy688 Member
    43
    Even after letting the material dry for two+ hours, it's wet to the touch... we ended up laminating the banner which I hate to do for such a short term banner.
  6. wes70
    wes70 Very Active Member
    1,661
    8
    38
    Oct 31, 2005
    Canada
    Is Jexar a coated banner for aqueous printers? Sounds like it's uncoated, suitable for solvent. If it coated, then you are laying down too much ink.
  7. BMurphy688
    BMurphy688 Member
    43
    Yes, Jexar is coated for aqueous printers... I too thought that, however, can not find many settings to alter the amount of ink put down.. It's either way to light with banding or my current problem...
    Brandon708, are you familiar with any settings to limit the amount of ink? In the driver section I've played with the production, etc... not much difference...
  8. Brandon708
    1,128
    48
    48
    Sep 22, 2009
    Orland Park, IL
    I will have to check on that monday.
    Sometimes when I print thru rip and print the ink comes out heavy and dark. I print a lot from the Windows printer. That way works pretty good.
  9. Bill Modzel
    Bill Modzel Active Member
    If it's not drying, you may be printing the wrong side of the stock.
  10. neil johnsen
    neil johnsen New Member
    4
    Jan 25, 2012
    Crscent, Iowa, USA
    Printer banner on jexar 10 oz
    I have the same printer and uv inks and have printed many banners. I use the Jexar 14 oz scrim though. After it's printed and dried, I usually wait a day, I clear coat it with Clear Shield liquid laminate. You can get it from Fellers and it comes in either matte or gloss finish. Use a high density foam roller and give it two light coats. The first aplication will really soak into the coating and you will see the over laps from the roller. Let it dry a few hrs and give it a second coat. With a little practice you will get good results. I can usually get about 500 sq. ft. coverage per gallon with the Clear Shield.
    Good luck,
    Neil
  11. Billct2
    Billct2 Major Contributor
    7,465
    642
    113
    Mar 12, 2005
    New England
    I do temp banners on HP aqueous printer. It does sound like the material is coated properly. When you load the material try selecting a different material to see if it's an ink coverage issue, but it sounds like a material issue.
Similar Threads - Jexar 10oz Water
  1. Enola
    4
    1,280
