Hello everyone.  I have a few questions.
My Cyan print head doesn't seem to be sucking any ink through. Mind you it was working perfect yesterday. I'll write down what's transpired the past few days.
I started off changing the light cyan print head. Installed it and took me forever aligning it. Everything seemed to work perfect. All heads were firing perfect (a few missing nozzles, but nothing worrisome).
So, today begins and the Cyan (large cyan) test draw looks brutal. Several cleans and it gets slowly worse. I then take the cover off and align the cap with my alignment tool. Run a clean and still not better. I then take the cap out and put a new one in.....again, nothing. So now i replace the damper.....nothing. Lastly i replace the pump....nothing.
Every time i run a hard clean or an ink fill up i'm watching the damper to see if i can see suction....and i do not.
I'm at a loss here. Any suggestions???
Thanks for all your input Signs101 nation.
