JFX200 2513 Ink Supply / Error 61b - White
Ronald Bodinger
Hello everyone!
After a successful installation of White and Clear yesterday on our recently acquired JFX200 2513 i was greated with an INK Supply W message on the machine today.
As well an Error 61b on Ink Channel 7 (White) when i manually try to do a Subtank Fillup
I checked the Ink Levels on that Inkchannel and the Subtank is half full.
Had tons of White ink on the Capping Station (Maybe overfilled?)
Pressure Check was fine and stable (Tested positive and Negative)
Any suggestion what it could be?
It´s funnily enough only occuring on this one channel.
Any guidance would be appreciated.
Ronald Bodinger
balstestrat
Problem Solver
Did you do the conversion yourself? What all did you actually do to do the conversion? I imagine it didn't have the white circulation so you fixed that up?
Ronald Bodinger
Yes, i did the conversion myself.
I wen´t step thru step from washing/flushing the system and re-routed everything with the diagrams in the Manual.
(Circulation Pump Route for 7/8) as well re-routed under the ink bottles (7-8)
I already did the Sensor Tests and Discharge / Fill UP tests.
After fill up (which does work) via the [HASHTAG]#Test[/HASHTAG] / Aeging mode i can see that the Second head is dropping white ink.
Thanks again
Ronald Bodinger
hand851
Roland Mutoh & Mimaki inks digiprint-parts.com
ERROR 61b
SUPPLY INK:12345678
Ink filling into the sub-tank has failed.
1. With [[HASHTAG]#TEST[/HASHTAG]]-[SENSOR], check the detection status
of the target liquid level detection sensor. (Also,
visually check the float position in the sub-tank.)
2. From [[HASHTAG]#TEST[/HASHTAG]]-[AGEING] - [PUMP MOTOR],
discharge ink in the sub-tank to the bottom.
From [[HASHTAG]#TEST[/HASHTAG]]-[AGEING] - [INK SUPPLY], check
that sending ink is performed.
*If sending ink cannot be performed: The supply
pump, the bottle valve and the UISS valve shall be
replaced.
