just started using vs640 - metallic on SIHL?
Discussion in 'Roland' started by WrapYourCar, Jul 2, 2012.
  1. WrapYourCar
    WrapYourCar Member
    157
    40
    28
    Jun 28, 2012
    Melbourne, Australia
    Hi Guys, is it possible to achieve a metallic/shiny looking silver on a SIHL 6329 stock (pull up banner), or is it always going to look quite dull? i'm not sure if i have set it up correctly, but what came out looked almost like no metallic ink was used!
    just started playing with the machine, the guy who sold it to me is not answering his phone, typical! once they have their $$$ they forget about you.
  2. WrapYourCar
    WrapYourCar Member
    157
    40
    28
    Jun 28, 2012
    sorry i mean 3629! (not 6329).
  3. tomence
    tomence Very Active Member
    1,647
    25
    48
    Feb 10, 2009
    IL
    You should be able to if your printer is setup with the white and silver inks. Also you need to use profile for that setup. If you use a CMYK profile only i dont think it will print any white or silver. Also you should know how to setup your files before print in your design software.
    Do you know how to use this printer at all, or are you learning?
  4. tomence
    1,647
    25
    48
    Feb 10, 2009
    IL
  5. WrapYourCar
    WrapYourCar Member
    157
    40
    28
    Jun 28, 2012
    Thanks Tomence, well just started using the printer for about 3 days, i know you have to select the exact Metallic Spot Colors from the design software ( in my case Adobe Illustrator), and it finds them in Versaworks, the profile might be where the problem is, as I was never given the correct profile for using the SIHL 3629 stock, i ended up just using a Profile for Avery 3000 (MT), which is of course a bit different still, perhaps i should search for a better profile!
  6. tomence
    1,647
    25
    48
    Feb 10, 2009
    IL
    The profile doesn't have to be exactly for SIHL, you just have to find a profile that works.
  7. DigitalPrintTech
    DigitalPrintTech New Member
    20
    Jul 3, 2012
    Whitewright, TX
    Tomence is correct, I have always said for years now, to many profiles to choose from.
    Find one that works all around and stick with it.
    My favorite is either GCVP or Premium Cast Vinyl.
    Now for your Metallic issue, obviously you have figured out that the profile must have the MT abbreviation next to the name, but also you need to select the correct print mode, basically telling the printer which inkset to use when printing that job (ie CMYKLcLmMT). Are you using the Roland Metallic color? You can also print the color swatchs for the Metallic table in VW. Click on Media/and selct which Metallic chart you want to print.
    Make sure to set your default color settings in VW prior to running this palettes.
    Edit/Queue A settings
    I will provide my favorite settings and see if they work for you.
    Quality Tab-For CMYK printing- GCVP Profile
    For CMYK + Metallic- GCVP MT
    For CMYK + White- Clear Static Cling MT
    Choose your correct print mode from the MODE menu
    Halftone- Select Error Difussion (v) (Note: works for most applications, sometimes lighter blues will appear grainy, if this happens just select DITHER)(( Use Dither if printing White))
    Color Management- Sign & Display- Click Properties button and select perceptual in the raster dropdown, and put a check in Use embedded ICC profile bottom left--Click OK
    Click on the File Format tab
    EPS Margin: .005
    Put a check in Spot Colors and Special Colors
    Click on Printer Controls Tab
    Media Feed Calibration- Select Use Printer Settings in dropdown
    Heaters- Custom in drop down- Print 35-Dryer 50
    Click OK
    Let me know if these help you...been using these settings for customers for a year or so, usually works great!
  8. WrapYourCar
    WrapYourCar Member
    157
    40
    28
    Jun 28, 2012
    Thanks DigitalPrintTech! that is very helpful, really appreciate your advice.
