JV3 1394 Board
Discussion in 'Mimaki' started by RSC, Aug 15, 2009.
  1. RSC
    RSC New Member
    15
    Any one ever have to replace the 1394 Fire wire board on your JV3?
    I need to replace mine and wont be able to get one till next week and am worried about the print heads until then. Will the printer run without the board using just the Parralel port?
    Any one know where to get a good price one?
  2. RippinPC
    RippinPC Member
    33
    Feb 20, 2007
    Cincinnati/Dayton Ohio
    Just do test draws and cleanings w/o the firewire board. It boots up with communication error, but doesn't stop the machine. Don't let the printer sit w/o power.
    I can get you one, but pricing from Mimaki is only going up.
    Chris
  3. Samurai_Screwdriver
    Samurai_Screwdriver Member
    112
    Get yourself a parallel cable and run your printer using that. It will print quite slowly but at least you'll still be able to get jobs out.
  4. RSC
    RSC New Member
    15
    1394 Board
    Well I replaced the 1394 board and am now still having trouble printing to the printer. I have re installed the drivers and it just wont send the jobs to the printer.
    I wonder there are several DIP switches on the board does it need to be programed at all? and in the upper righ hand cornner of the board there are 12 green LED's are those all supposed to be lit when the unit is powered up?
    Thanks for your help
  5. Samurai_Screwdriver
    112
    Definitely don't touch the DIP switches!
    The real key here is to see whether the Mimaki is being seen by Windows. Looking in the Device Manager you should see to items "Mimaki Printer Port" and "Mimaki Status Port".
    Also, the board, if it was brand new may have FW too recent to be compatible with the driver loaded on your PC. Make sure you've got the latest from www.mimaki.co.jp
