-tail-end of a large project, and magenta starts printing 25% on 12/16 passes.
--cancel print, run test draw, nozzles @ 100%
-ink supply not refreshing. confirmed by drawing ink from below capping station, and hearing hissing noise.
--replaced damper, no more hissing, ink flowing good, should be good2go!
wrong...
-now 0% nozzles firing on test draw on all channels!
nozzle wash, fillupink, test draw...same thing, nada.
I pull my ribbon cables out and notice that, at the slider board, the top cable is slightly kinked (#1/5). closer inspection... crunchy to the touch, I don't know how or when (most likely during damper swap) I must have pinched the ribbon cable?
--unsure if it is the cause, but IF it were kinked/connection severed... is it safe to think this could be the cause of printer running as usual but simply not firing ink whatsoever? no errors, all operations per usual, just no ink firing...
debating pulling the cable and running to radioshack to see if they either have another one, or they can shorten/strip the one I have.... but want to make sure I'm not too jaded to consider other options before "major surgery".
wrong...
