JV3 160sp
ChicagoGraphics
Does anyone know if you can tighen the pinch rollers on the JV3 160sp, I noticed most of the right side pinch rollers towards the control pannel just spin and not really holding, is there something I can tighen to hold my matriels better.
Thanks in advance
artbot
you can switch out the springs for a stronger ones. all my springs on my jv3 are switched out. take out a spring, when at the hardware store (the good stores have a drawer with a zillion springs) match the general circumference, get springs that are a little stiffer. if you can match the length that's great. but, you probably will not be that lucky. now with wire cutters and two needle nose pliers, do some "spring surgery" to make then the right length. when doing the install, you will need to snap off the black plastic protective sleds.
if you are desperate, you can take out the OEM spring and cut off a few turns, then put it back on.
