jv3 nozzle deflection question
NitroSigns
I have bad deflection on one of my heads. I let it soak for about 24 hours and it is still doing the same. Will it hurt to use a syringe and flush cleaning fluid through the head from the top?
artbot
the head prefers vacuum to positive pressure. if you can set up a damper with a tube going to a cup of cleaning solution and pull it through from the waste line. also pushing fluid at the carriage runs a great risk of the the tube or damper popping off and spitting fluid all over your heads. not good.
