JV3 parallel communicaton issues
Quix
Hello to all.
I’m repairing a JV3 printer which has a faulty firewire card.
I connected it by the centronics (parallel) port and it works, but while printing it “waits” a few seconds between passes. I assume it has something to do with data transfer speed.
Is this behavior to be expected using parallel cable?
Thank you for your help.
omgsideburns
It makes sense.
How can I check that? Is it set by the printer, or by the software?
Thank you
It's an option on the printer. I'm unsure on the JV3 but on the JV33's interface it's: Function > Setup > Type (choose which user type) > Drying Time .. And then adjust the "Scan" time
genericname
This is a known issue with a parallel connection to the JV3. You can try to set the refresh rate to nothing, but it waiting doesn't necessarily mean there's anything wrong going on other than a really slow transfer.
SightLine
That was our experience years back when I had a JV3..... firewire card went out (sent off to Mac Media to get fixed). So we tried running on parallel while the card was out. Quickly realized that was an effort in futility and that the machine was useless connected that way. Well unless we wanted to print 1 van wrap for the next 7 days.....
