JV3 Trouble
RSC
Anyone ran into their JV3 booting up and hanging at the <LOCAL> screen prompt on the display?
I ran a print and shortly into the print I realized I wasn’t happy with the print so I canceled the print through Wasatch. After that is when we had the problem. After Wasatch stopped working it will begin to start up then crash as well as the printer wont boot past the <LOCAL> prompt.
I re-installed the fire wire driver as well as Wasatch still no luck. Before the canceled job it was working just fine?
wrapman jamz
Power down the unit for 30 minutes. (This means UNPLUG IT) it will wipe the memory in the motherboard. Then start it back up...if this does not help, call Mimaki in the morning.
ColesCreations
Even might work to just unplug (or turn off switch in the back) for a few seconds, then back on. This worked for us when having similar problems. If not, try 30 min's...
