JV33-160, not printing any color
Any help would be greatly appreciated.
Yesterday printer was working fine, nozzle status was perfect. No issues what so ever.
Today, the machine will not print any color. Tried a nozzle status, not one color is showing. Machine is powering up normally but simply will not print any color. Even tried a test print, machine behaves normally except for that nothing is printing.
I'm assuming it's something electronic. I've rebooted the printer and checked the ribbon cable going to the head, it seems to be seated firmly. That had no effect.
Not sure what to do next.
Thanks,
Chris
Devlinjay
Check to see if your pump is pulling ink through the capping station. I was told that if the seal on the capping station is bad, the pump can not prime the head. I had this problem once before. They changed the pump and the capping station and everything worked perfect after that.
After finally getting a Tech on the phone, they came up with the same conclusion.
Parts are being delivered today. Hopefully we'll be back up and running a little later today.
Thanks,
Chris
