JV33-160 vs Flexi
Compilla
Trying to set a JV33-160 on FlexiSignPro 8.6v2
The printer is connected via USB
What port do I need to select ?
Tried All USB port Available, no luck
Check on Printer and faxes and shows to be set on RLP Mono, so I set it up on Flexi
But it does not communicate, it Rips the file but it won't send
Any Ideas??
Matt-Tastic
go to your device manager and make sure windows sees your printer. there will be a item called mimaki something-or-other, with a data port and a status port underneath it.
if you don't see that, unplug the printer, go get the drivers from mimaki and let us know if it works after you've installed the drivers.
the thing under printers and faxes is the Rasterlink Pro hotfolder driver, most likely. were you running this under RLP before you got flexi?
oh yeah, the port for your mimaki should be called something like USB_Printer_0.
Compilla
Thanks for the replay.
You pointed me to the right direction...
Yes, I was running the Raster Ink Pro Software before. We just got Flexi
to be able to Contour Cut...
:peace!:
