Andrew Signs
Hi All,
So I have searched around and tried to piece this together. I'm having a range of issues with one of our JV33s (we run several).
Main points
- One side of black is not firing (left hand side) - 100% not firing.
- After a few cleans and washed I got a couple of nozzles but only until we did the next fill
- It was functioning fine until yesterday
- The head cables were replaced today
- Ink is flowing to the damper - confirm by opening valves and letting flow
- Pump is brand new put in 2 weeks
- Capping new
We have done al the normal head cleans, fills etc with no luck. The odd things are below;
- It seems to me that the damper on that black channel isn't 'sucking in' as other the others do
- I swapped the two black dampers to test if it was the line. Following this the same left side still doesn't work even with other line/damper
- To test, we manually primed the head with black on the side that wasn't working. This worked and ink fired as normal but no ink pulled into the head therefore is only used what was available in head.
So...this leaves me questioning what to try next. I know everyone always falls on replace the head and just want to see if I've ticked all the boxes before we spend the money on it.
Any help wold be greatly appreciated.
Main points
- Capping new
