Jv33
jaly723
Does anyone know how to re-adjust the head on the JV33. I have had it for over a year and have printed on it a lot. Just think I need to adjust the bi-calibration.
Masseria
To check if you need to re-adjust bi-lateral printing. Make several straight lines and print them.
if the lines are not straight as they should be. then you need to adjust it.
I run the jv33 like 24/7 for 2 months and never need to re-adjust.
You may want to attach a picture if you having problems. and also if you had a media crash you may want to re-adjust as well.
Hardware Calibration or Software Calibration?
Hardware you need special tools. such as optical zoom and know how the do this.
Software Calibration you just have to do a Drop Pos Correct, in mimaki's jv33 menu.
(i think the path is this but not sure)
Local Mode => Function => Maintenance => Drop pos Correct.
You can also check the flowchart in the jv33 operation manual to see the exact path.-
Bye.
