I did a rail lubrication like normal and then the carriage moved back and forth to spread the lubricant. When it got to the left side it made a loud noise and gave the 86:01 Substrate Jam warning. There was no substrate in the printer. I did get a spot of oil on the encoder strip while lubricating but wiped it off right away, before the carriage was ever moved. I did further research which says you can clean the encoder strip with tap water and a lint free cloth so I've done that several times. Every time, upon initialization, I get the same 86:01 when the carriage gets to the left hand side.
Any suggestions on what else to do? There is definitely nothing physically causing the jam. Have I ruined the encoder strip by getting that spot of oil on it even though I wiped it right off and then further cleaned it? If so it that something I can replace myself? This is our only printer so getting it going quickly is important.
