Kerning gone weird!!
Discussion in 'General Software' started by Dave Drane, Jun 7, 2006.
  1. Dave Drane
    Dave Drane Very Active Member
    2,540
    1
    I have a job set up and one word in it goes weird when sent to cut file. I node edited most of the copy and just one word "Motel" when sent to the cutfile tightens the kerning but says the lenght is as stated on the job and then cuts WYSIWYG from the cutfile??? Anyone know why this would happen. I thought about it overnight and thought maybe I should have converted the text to curves and tried that. It is no biggie but just a nuisance.:wine-smi:
  2. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    what software & hardware Dave?
  3. Dave Drane
    2,540
    1
    VMP (VinylMaster Pro) and Graphtec plotter Doug. After you do the design you send it to plotfile and then cutter. It shows what it is going to cut in the cutfile but it is different to what you see in in the design platform although it shows the lenght as being the same.??
  4. Si Allen
    Si Allen Very Active Member
    2,146
    1
    Hmmmmm! "MOTEL" Isn't that where you 'get together' ?
    :rolleyes:
  5. Cadmn
    Cadmn Very Active Member
    2,859
    Dave just curious you making one of the designs from the other thread if so Kewl Is it for & NO tell M o t e l ? :)
  6. Si Allen
    2,146
    1
    Rewmember....Motel spelled backwards is :
    Letom!
  7. Dave Drane
    2,540
    1
    Letom go or letom at it!!
