Knife Offset
Discussion in 'Miscellaneous Plotters' started by Bigdawg, Oct 23, 2005.
  1. Bigdawg
    Bigdawg Just Me
    7,462
    133
    63
    Jun 8, 2005
    Sunny Florida
    I have a Master's 24" cutter. Haven't had a bit of problem with it so far. But I was cutting thermo today and noticed some smaller letters aren't cutting square corners like it should. I opened the plotter prefs and the knife offset was on.30mm and 45 degrees... Can anyone explain to me how the Knife offset works and what it affects? The manual is worthless.
    Any other suggestions? And please... no responses like "get a real cutter..." I'm already saving for one!
    Thanks!
  2. signage
    signage Major Contributor
    10,699
    291
    83
    Oct 5, 2005
    Penn
    Stacy,
  3. signage
    10,699
    291
    83
    Oct 5, 2005
    Penn
    Stacy,
    The offset is the distance of the cutting edge to the center of the holder. This distance varies on different degree knives and depth settings. When you do a test cut and the corners or start stop positions are off you compensate for these through the knife offset. This offset can be positive or negative depending on what is occurring, this setting will compensate for the blade (knife) not being centered in the pen/blade holder. A pen is always centered in the holder. I hope this helps. I think you want a positive offset to correct your problem.
    Brian
  4. tat2shawn
    tat2shawn New Member
    8
    Hi...
    I have the same cutter. A good start point for the offset is 0.012
    Hope this helps.
  5. signage
    10,699
    291
    83
    Oct 5, 2005
    Penn
    If corners are rounded you need to increase the offser, If they are turning out with too much of a point you need to decrease the offset. The angle setting shpuld match the angle of the blade you have installed in the plotter. Hope this answered you question.
  6. Bigdawg
    Bigdawg Just Me
    7,462
    133
    63
    Jun 8, 2005
    Sunny Florida
    Thanks guys - appreciate the info!
