Got a job coming up shortly and it would take forever to get right trying to pre-cut... basically I'll be filling in pre-striped designs with a chrome film. The original striping will be covered, but trying to match the existing with a template/cut started as a nightmare. So I decide that the knifeless tape system looks like the answer, but I have some questions;
1. As this will be adding designs/striping, it looks like the newer Designline tape would work best. The brochure recommends 2-3mil vinyl and that leads to the next question
2. I had originally planned on using Oracal 352 silver, but it's a 1mil metallized polyester, anyone know if the system will work with that and leave clean edges? I looked at Avery's Conform chrome, but at 5.7mil, I was concerned with overlaying a vinyl pinstripe (cast, pre-cut on a cutter) over the edges as the customer is scared of paint. The thickness of that is also outside the recommendation of the system.
Thoughts or advice? And as this is something newer to me, I will certainly be running a few practice pieces on my own vehicles before the install to get comfortable, just looking for a good starting point or known bad ideas to be pointed out from above
