L25500 Adhesive Vinyl shrinkage
Discussion in 'Hewlett Packard' started by Quix, Jul 4, 2012.
  1. Quix
    Quix Member
    73
    Mar 9, 2011
    Mexico
    Hello to all
    I've been using my HP L25500 for about 8 months.
    I'm printing on an italian Kemica TecPrint vinyl for solvent printers (i think it's a general formulation) without any issues so far.
    Recently I printed lots of 8"X12" labels that were ment to be contour-cutted with a Mimaki CG-SRII, after lamination. For this I had to print the specified marks so the plotter could set the printing parameters.
    I noticed a deviation of about 1/8" from the marks printed in the middle of the vinyl, in relation to the ones in the borders. This made me waste almost a half of the printed area (only the central prints were straight).
    I wonder if any of you could recommend me a vinyl type that can help me to solve this problem.
    Where I live I have no access to all the brands you talk about in this forums, so a common brand such as Oracal, Arlon, 3M, Avery would make a better recommendation.
    Thank you!
  2. ddarlak
    ddarlak Trump Hater
    i would imagine anything not calandered would be fine
  3. Desert_Signs
    Desert_Signs Active Member
    653
    2
    There is a setting in the firmware to correct this. Straightness optimization I think it's called. It's been a while since I "fixed" mine, but if I remember right, it's in the image quality section. You have to print a straight line the width of the vinyl, then measure the "bow" in the middle. Put in the adjustment and it should fix the problem. It's in MM.
  4. ProColorGraphics
    ProColorGraphics Very Active Member
    1,450
    89
    48
    Apr 1, 2009
    Minnesota
    It is straightness optimization. If you are ever in the market to upgrade your cutter, the Summa's actually print a line across the width of the print and read that as well to help correct the "bowing" in the prints on the HP Latex. I just upgraded to the S-Class T series. Expensive, but well worth the money!!
  5. Quix
    Quix Member
    73
    Mar 9, 2011
    Mexico
    Thank you all for your replies.
    I changed the Straightness Optimization setting and it helped a lot.
    The next step should be buying that new Summa cutter you recommend. Looks very nice, strong, ...and expensive :)
Similar Threads - L25500 Adhesive Vinyl
  1. Emerald Vinyl
    16
    562
  2. Emerald Vinyl
    2
    351
  3. tomcnc
    9
    573
  4. MrTopgun21
    465
  5. Bubba06
    7
    608
