L25500 - Error Code 15:03:00
Dave Rowland
Hi
I am new user.... after googling around it appears to be
15.03:00 - Drying system temperature too high
Really?
I am using the 3M IJ 40-10 in the UK on Onyx
second time i had this in a few days of owning it, do u think the profile is set too high or do u think i have an issue with the machine?
is it regular message?
Hicalibersigns
We have had ours for 7 months. Grimco rep was by a few days ago and lowered all of the max temps on our profiles by 10%. Said they found that they were all set slightly too high. We have not noticed any adverse affects. Turn it down a bit.
Dave Rowland
Just done it again...
Drying is 55Deg
Curing 110deg
heat airflow 40
update: this has just turned into a problem, everytime i start it i get the message.
dypinc
Where do you get the error code, RIP or printer?
What is your Minimum drying power set at?
How many passes?
Dave Rowland
onyx... this is a HP error but it is echo'd on the RIP.
the drying power, not seen that yet
i shall switch in the printer shortly, see it what if it is going to work.
this is my 4th time in 2 days since owning it... from comments above i am thinking that I am only getting this error
dypinc
15.3 Excessive heat in the drying module. Check that all fans are working and unblocked. If the
problem persists, call your service representative.
