L25500 Substrate Unload - Not unloading!
Desert_Signs
I go into the menu, hit substrate unload, then hit OK on unload and nothing happens. What have I messed up? :Oops:
Any ideas?
Also, I can't unload with the substrate feed arrows. It stops just before the substrate comes out. End up having to lift the big blue lever and tug the vinyl out (which it doesn't seem happy to do).
HulkSmash
First: @Josh, thanks for reminding me. I'm registered over there too. I'll post.
I'm actually talking about unload. I load the same way you do.
oops, i guess i should learn to read.
I have the issue as well sometimes. Just power it off, lift the blue lever, and pull it through.
