currentcreation
I can't get this L25500 to start up. The screen lights up with the rectangle and just sits there.
Anyone see this before?
I had this happen to my L25500 last year. We tried replacing all the computer components one by one. Turns out, it was a bad memory stick. Using a memory stick that matched the specs from a PC would NOT work. However, when I ordered the official part from HP, the printer started right up.
It was 2 weeks of hell.....just for it to be a memory stick.
-Alfred
thanks for the info. do you happen to have a link, part number or any further info on this memory stick?
Hey. Another question.
I keep getting these 'possible substrate jam' errors while it is warming up.
I have cleaned the carriage rails and oiled them. Is there something else that would cause it to get stuck on one end or the other?
It runs the length of the rail and then gets stuck on the end. Can't seem to find the cause.
went over the strip a few times again, just to be sure. also cleaned off the reflector and the red lens.
it is stopping right before it goes into the far left ISS area.
edit:
..well, back to getting stuck on both ends.
i wonder if it needs new felts. they seem to be ok. soaked with oil, but ok.
I don't believe it is the felts. When the felts go bad the machine ask for carriage rail cleaning and lubricating all the time. Bad felts make friction. I have changed bushings 2-3 times and the whole ******* carriage once but never had problems like you are having. Just constant clean and lubricate messages
My machine had something strange with the original carriage, bushings wore out uneavenly which wasnt supposed to be possible. We changed the whole carriage, it took 4 hours and service manual. HP's are easy to fix by yourself and believe be , we don't have any skills for that
You can buy bushings and felts with 100$ from ebay.
hmm. bushings. haven't looked into that yet.
not concerned with ability to fix it, just locating the problem that is giving me a headache.
thanks to everyone for the input.
ordered a bushing/felt kit just to be sure.
-Alfred
I also wanted to mention for anyone else having a problem with the initialization and not even getting to the point where the carriage starts moving. I didn't need to replace the RAM, only to remove and reseat it.
