L26500 sheet printing capability?
RoCo
About to make a purchase...Is it possible to print on sheet media (like an Epson can)? or is it strictly roll-to-roll. I can't find anything in the literature that says it can or can't.
dypinc
Not designed to print on sheets. I suppose you might be able to fool it by taping sheets to a roll.
MikePro
+1
its the only thing I miss about my jv3, being able to keep scraps of vinyl lying around and simply telling it to print... even putting tape over sensors to lie to the machine that the media is larger than it actually is so I can print on as much of the area as possible.
....still, I've had no regrets since making the purchase. the HP26500 is just simply AWESOME!
JoeBoomer
Even if it worked for sheets, I would avoid at all cost
The warmup time for this printer is way too long to make printing on sheets feasible. Other than that, this printer is awesome.
FrankW
One Problem is that the distance between the printing area and the media sensor is higher than on much other printers. So you loose a lot of your sheet which is not printable.
The next Problem is that the HP is designed to work with a fixed Y-Origin, which is hard to find when not rolling from the media holder.
RoCo
That's pretty much what I thought, since the promotional stuff didn't mention it. Thanks, everyone!
