rudeez
Hi.
I have this customer wich orders labels in the size of 11 x 32 mm usually, sometimes a bit bigger, sometimes a bit smaller.
Until now i have printed those on Armalex 5 mil using mirror printing on the backside and then 3M 467 adhesive on the backside of it. They use it for marking on crimping hand tools like THIS.
Now, they have disconntinued the manufacturing of Armalex 5 mil aswell as the LexEdge 5 mil material and the only one i found avilable is the 1 mil of both materials wich is way to thick. I have tried printing this thickness and cutting it and it's just not as good for this kind of application.
I now have the biggest problem to solve, they order about 300.000 of this type of labels every year and i can't afford to loose them as a customer.
Is there any good substitute material for this or any good way to approach it?
I tried to print on "normal" vinyl aswell like the oracal 751 and then laminate it it with the same 5 mil using 467 adhesive since i diden't have the ordinary armalex laminate with the original adhesive on but still it's quite to small to cut correctly and still a bit to thick.
Help me solve this issue and you will be rewarded with alot of handshaking and hugs...
Maybe there is still someone who manufacter this type of product?
Best Regards Jimmie
Best Regards Jimmie
