Laminate On Indoor Perf?
Discussion in 'Newbie Forum' started by Hip Pocket, Oct 16, 2018.
  1. Hip Pocket
    Hip Pocket New Member
    16
    Sep 21, 2018
    Wisconsin
    Is (spray) laminate needed for indoor perf vinyl? From what I'm seeing it's value is UV/chemical protection and water repellant from holes...We have a customer that wants perf on an inside door? Thanks.
  2. ledhead
    ledhead New Member
    19
    7
    3
    Dec 4, 2017
    Midwest
    We use a clear cold laminate on most of our indoor perfs. It is not quite necessary if they are not in direct sunlight but it speeds up application. Also if they are in a well trafficked area where they could be rubbed up against it provides protection from scratches and the like.
  3. Hip Pocket
    16
    Sep 21, 2018
    Wisconsin
    Thanks for the info. What about using a spray laminate?
  4. ledhead
    ledhead New Member
    19
    7
    3
    Dec 4, 2017
    Midwest
    We only use wet laminates when our perf is sized bigger than our laminate width. We try to avoid that so I will not be much help. Sorry
  5. Hip Pocket
    16
    Sep 21, 2018
    Wisconsin
  6. bannertime
    bannertime Very Active Member
    2,160
    505
    113
    Sep 8, 2016
    No
    Spray laminate with perf takes some practice. It can fill the holes and become cloudy or chip off during installation.
  7. shoresigns
    shoresigns Very Active Member
    1,535
    300
    83
    Nov 1, 2011
    Vancouver, BC
    On the rare occasion we install perf indoors, we don't laminate it. Unlaminated perf is super easy to install since it's full of holes.
    Make sure the client understands that if you install perf on the interior side of an exterior window (facing the interior), it may be hard to see during the day unless the interior lighting is quite bright.
    • Agree Agree x 1
  8. Texas_Signmaker
    Texas_Signmaker Very Active Signmaker
    4,916
    1,827
    113
    Oct 21, 2016
    Frisco, TX
    I agree, much easier to install unlam perf. Indoors shouldn't require it.
