Laminate Vision Film
timandmikki
I recently installed vision film on a building without laminating. The film became scratched and now I have to re-install. I was wondering if anyone has every used Clearshield liquid laminate on vision film to protect the print?
rturner381
"laminate vision film"
Good day, from the title of your post, it sounds like your print must be optically clear upon installation. What printer are you using? If you use the liquid lam, then the liquid that fills the holes will be removed when your backer is removed. Therefore, the holes will be a little bit deeper, allowing the water to collect. On the other hand, if you use an optically clear laminate, you eliminate the water collection issue.
