laminating question
Discussion in 'Digital Printing' started by signwizz, Jun 3, 2011.
  1. signwizz
    signwizz Active Member
    i printed some die cut stickers then laminated then put in then die cut but it was off.but when i do a print and cut with no lam they r perfect is that normal
    shane
  2. WrapperX
    WrapperX Active Member
    754
    Do you have "profile" or type setting on your plotter? If so you should set one up for unlaminated vinyl and one for laminated vinyl. The cut depth and pressure is gonna be different for the two types and you might be getting a little resistance from the laminated vinyls which could - over the course of the cut - could pull the vinyl out of "alignment.
  3. Mike F
    Mike F Active Member
    750
    2
    18
    May 11, 2011
    It might help if we knew what machine(s) you were using as well.
  4. signwizz
    sorry roland sp300 v
  5. ProWraps
    ProWraps Very Active Member
    3,556
    Sep 30, 2009
    San Francisco, CA
    is it off horizontally or vertically? possible that maybe your laminator is stretching your media? not sure how that would happen but could be the case.
  6. Designer Wraps
    Designer Wraps Member
    364
    Aug 28, 2007
    NJ
    How thick is the laminate you're using?
  7. signs+banners
    signs+banners New Member
    17
    did you run an environmental match before you cut?
  8. Double Diamond
    Double Diamond Member
    59
    We have a roland and compensate by creating a bleed if possible, smaller area by doing more groups instead of one big one, and we do a enviro match before print and before cut. The y axis usually is ok, but he x is off 1/8" avery 4' or so. J
  9. Gino
    Gino Premium Subscriber
    33,288
    2,321
    113
    Jun 7, 2006
    PA
    Some laminates create a little too much sloppiness from the glossiness and cause the media to move ever-so-slightly if your pinch rollers aren't tight enough.
  10. Mike Paul
    Mike Paul Major Contributor
    5,438
    8
    38
    Dec 30, 2003
    NJ
    Do a print/cut adjustment, do an environmental match, make sure your heaters are off and cooled down before cutting.
