Laminating ucjv300 print without heat
willkho
Hi all,
Need help or advice here.
I got a ucjv300 and a flat applicator with no heat assist.
I heard that UV print is hard to be laminated.
Wondering anyone know the trick to do it with the flatbed applicator? Probably there is a laminate that work better with UV ink that no requires heat assist?
The vinyl I'm using is Arlon 4600.
Thank you
White Haus
Not a Newbie
We've been running and laminating prints from a UCJV for almost 5 years now. Heat assist is suggested/probably a good idea, depending on what you're doing. Our printer came with a Mimaki laminator w/ heat assist, probably because they knew it required it. I take it they've abandoned that program by now.
Silvering will be present/obvious on any dark areas of print, and around any edges of vector print lines/shapes. Silvering on dark print areas does go away over time, but doesn't look too good at first and will show pressure points from rollers, pneumatic feet, fingers, rulers while processing/finishing prints.
We mainly use a cast gloss (3M 8418G) on prints from this machine but occasionally use Avery DOL 2080 matte, and we usually use a bit of heat assist.
Long story short, I'd suggest figuring out a way to add/use heat assist for laminating prints of this unit if you're counting on shipping prints shortly after finishing.
If you're mostly doing small decals however, it shouldn't be a problem. Do some testing, and make your own observations.
Alternatively for small decals, you may find that laminate isn't even required. The prints off those things are pretty scratch resistant.
