Need Help laminating..
Geneva Olson
Expert Storyteller
so. does anyone have any tips on laminating smaller widths than the roll? i have a 54 inch laminator but i want to run 30 inch material and 48 inch material through it.
WYLDGFI
Center it up and use a good tape measure to get the rolls straight..the media and the lamination. As long as your laminator feeds straight, you should be fine.
Boudica
What Bill said, also, if you save your liner for feed, you can put it beneath the vinyl and run it through. so the extra lam sticks to that instead of your laminator.
ledhead
Is your laminate 54 inch? If so, in our shop we use the wasted paper backing from laminate. it does not work the greatest with longer lengths but for short pieces it works fine. It likes to get bunch up and wrinkle on the longer runs. Hope this helps.
Geneva Olson
Expert Storyteller
I've done that and it seems to bunch up under. Is there a trick ? perhaps tape it?
no, just looked for a video with a sled.
we have daige quikmount 3 38"
daige quikmount 55"
royal sovereign 65"
seal 4000 44" heated
Geneva Olson
Expert Storyteller
daige quikmount 55"
royal sovereign 65"
well, My original question was running a piece not as wide as the 54 inches through. I don't have a piece of laminate to place on top to do that with. So, it doesn't seem to make sense to do this.
Unless I'm missing something.
Ok, what's a sled?
Sorry! I missed this question last week...
A "sled" is a piece of board with mounting adhesive applied to one side that has the release paper left on - this make a surface that the laminate won't stick to. You put the piece of vinyl down on the sled, then take a piece of laminate cut a bit larger than your printed piece and start it was printed adhesive vinyl you were going to mount.
Here's a real quick example:
Also, found this video...it's a small manual laminator, but it's all the same idea. Looks like someone else posted the same video! I'll leave it here anyway. Hope this helps!
