laminator recommendations wanted
Discussion in 'Newbie Forum' started by koigal, Jun 7, 2010.
  1. koigal
    koigal New Member
    5
    I'm looking to add a laminator to my small business. I have a roland versacamm (which I love), and an HP 5000 ps UV (which I'm ok with, but not nearly the love that I have for my versacamm! lol)...
    I have a little 24 inch simple roller laminator that I've been using to laminate prints but it is time to upgrade to a real laminator as my orders have increased. Also it would be nice to do wider things.
    I've learned so much from you all as a lurker - I'm hoping to learn more about your experiences with different laminators - my needs are to laminate - not mount...and space is a consideration - I am working in fairly cramped conditions so I'd like to not have to dedicate a room to this....
    I've searched this forum and read up on laminator postings but could really use a more detailed discussion of good laminators
    I've got an opportunity to buy a bienfang 42 (someone locally has one they are selling) but I'm wondering about the "signmaster" and gbc laminators as well. I've read I should try to stay away from Daige)...I want to keep it under 5K total (as far under as I can) but I know that you do "get what you pay for" in this regard.
    90% of what I laminate is prints that are 20 inches or so in width. With a larger laminator I can run them 2 up and hopefully speed things up around here -
    Any and all advice is greatly appreciated. Also, is there a tougher laminate you recommend my prints get touched a lot and I just want to keep them looking nicer longer. They are mounted on a slightly curved surface so I need something with complex conformability.
    Thanks in advance!
    -Karen
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    19
    welcome from cali :thumb:
  3. omgsideburns
    omgsideburns Very Active Member
    2,181
    1
    38
    Apr 15, 2008
    Columbus, OH
    got a gbc.. love it. no problems ever.
  4. Gino
    Gino Premium Subscriber
    34,455
    2,626
    113
    Jun 7, 2006
    PA
    Welcome from PA...................................
  5. marcsitkin
    marcsitkin Member
    168
    1
    Laminator
    I've had 4 laminators over the past 25 years, and by far the best is the AGL I currently own. You can almost throw your material at the machine and get a perfect laminate.
    Only caveat is that you should NOT run thermal vinyl overlaminate in this machine. It can damage the rollers. That said, it has no problems with any cold vinyls or with any other heat assist materials.
    Unlike may others, it's AMERICAN made.
  6. k.a.s.
    k.a.s. Very Active Member
    1,411
    4
    38
    Aug 8, 2003
    NE ohio
    If you can spend a little more, buy a Seal. They are awesome. I have heard good things about a Royal Sovereign, I think they are around $5000.
    Kevin
  7. BALLPARK
    BALLPARK Member
    496
    42
    28
    Dec 5, 2008
    Radford, VA
    I have only used Seal & Royal Sovereign, both are great work horses.
    I like the Seal series a bit more, but they cost more as well. I think you would be very pleased to have either of them in your shop.
  8. Rydaddy
    Rydaddy Member
    184
    1
    18
    Feb 23, 2010
    Michigan
    If you don't mind me asking which AGL laminator do you have?
  9. Stealth Ryder
    Stealth Ryder Very Active Member
    1,722
    Jul 16, 2009
    Texas
    Welcome from Texas...
  10. Fuzzbuster
    Fuzzbuster Active Member
    554
    Mar 23, 2008
    Ottawa
    Welcome to Our forums???????????????????????????:Welcome:
    :popcorn:
  11. marcsitkin
    marcsitkin Member
    168
    1
    Similar to the current Encore Maxim, 61" dual heated rollers
  12. Jeff kcc
    Jeff kcc New Member
    1
    Nov 3, 2012
    San Francisco
  13. WYLDGFI
    WYLDGFI Merchant Member
    1,619
    297
    83
    Oct 27, 2006
    Linden, NJ
    Welcome aboard....where are you located??
    I second the AGL laminator. We have had one for a year now and absolutely love ours. They have an imported version called the Compadre which is still a nice machine and supported by AGL.
