laminator
threeputt
Our 61" Arctic GBC Titan is a little on the pricey side but it's well built. It's a cold laminator, no heating element.
high impact
DO a search and I think you'll find it has been discussed before.
I have a new Daige 55" - I have had absolutley no problems with it other than I had to loop the drive belt into a figure eight to use oracal laminate(reverse wound). I use no sled or paper! I just wipe wd-40 on the rear table portion and it works incredibly well. Others will argue that the Daige is junk but for the money and how well it works for us - I can't complain at all.
Munch
I use a 60" PRO-LAM with heat assist.
It does a nice job for mounting as well.
Unit is distributed by SIGN SUPPY USA.
I previously used their ROYAL SOVEREIGN by I did not like haveing to use a "delaminating" paper in the lower unit. The waste factor was also high due to the roller configuration.
