Need Help Large bubbles when applying vinyl to board
I bought a second laminator so I could apply my laminated vinyl prints to substrates. It almost always leaves large bubbles where the vinyl is not applied to the signs. Even if the bubbles aren’t visible, if I take a squeegee I will see a bunch of large pockets of air. It’s so bad that I’ve had to reprint very large prints just to redo it by hand….
I’ve tried pressure changes and I’ve tried using heat but the bubbles remain. Any ideas why this is happening ??
use a spray bottle, mist the substrate with alcohol.
wipe with microfiber cloth
flip substrate & repeat
you say you bought a second laminator. the first was too small?
you didn't have this issue with the first?
All substrates are cleaned with alcohol and a mircrofiber cloth before applying the vinyl.
I never used my other one to apply vinyl on boards. I know its a bit weird, but I do not want to use my first laminator for anything other than laminating film to perserve the rollers. They are both 60" laminators. The purpose of me purchasing the second laminator was for my own sake of mind knowing there would be some sharp edges hitting the rollers. (I do file down the edges still.)
I purchased this "new" laminator used. Its worked well for laminating pieces (I set my other laminator to be used roll to roll) And it has also worked for applying transfer tape so without any bubbles.
are you SURE there is not a flat spot?
i have a 55 inch daige, that must be 25 years old. bought it used and the bottom rollers were TERRIBLE.
i use it for nothing other than mounting to a substrate.
i cheat and sandwich what i am laminating
10mm coro on the bottom, then my substrate, then the vinyl + laminate on top
the coro "takes up the slack"
you never get a bubble
5 years ago,,i said i would do this for a while and then get rid of the old daige.
it is still going strong
Geneva Olson
Expert Storyteller
Is the air bubble in the same place every time? I would imagine that your rollers aren't evenly distributing pressure across the substrate.
JBurton
Signtologist
My money is on too much nip pressure, but it's really hard to make out the shape and spacing of the bubbles in these pictures.
