large hanging backlits? material?
fozzie
have a client who wants a material that can be backlit for a convention center entrance (indoors)
list of requirements/wants
1. 4 each 5' x 30', 4 each 4' x 15', 4 each 3' x 11'
2. all will be suspended (freehanging) using pole pockets top and bottom. they are all portrait orientation (ie. 5' wide x 30' tall)
3. no curl on the edges (prefer no hems)
4. would be backlit with spotlight type lighting. client knows they will have hot spots / inconsistent lighting
5. colors that are rich and true to their corporate identity
due to tight schedule, we will need to produce in house. we have eco-solvent and uv printers. no dye-sub
would 3M panagraphics III be suitable? never used it. wonder about side curl?
any suggestions/help greatly appreciated.
thanks in advance.
chafro
There is some amazing backlit banner out there. It comes out beautifull in latex, I'm sure you can do something similar in uv or ecosolv.
thanks in advance.
We use polystyrene for these backlit marquees we print for the local theater.
BigfishDM
Yes the Cooley product is the best stuff I have seen for that application, its a little pricey but you get what you pay for and its a high end application so you should still have plenty of margin to use the right stuff.
