Large Print 6ft x 48ft
funnyb0nz
So I have my first large print. Customer gave me a Publisher document and when blown up to 6ft x 48 foot it looked like garbage. So I redesigned in Illustrator. So my guestion is I am useing 54 inch material. How do you guys go about printing the image? How much overlap do you do on the side that will have seam? I have read some use 1inch (because walls arent straight all the time).
This print is going on conference room wall inside building. Also do most of you laminate indoor graphics? I have always laminated everything I have done, however its been signage for outdoors. So any pointers are greatly appreciated.
Thanks in advance!
Behrmon
Pr. Bear-Mon
I'd run 2 Horizontal panels w a 1" overlap and a couple inches of Bleed Bttm and one Side. If you use a substrate that needs to be laminated I'd strongly suggest Satin or Matte, nothing worse IMO that a glossy wet paint looking wall!
funnyb0nz
48foot long you would run 2? It would look better with 1 seem, however I am tackling this myself with no help.
JBurton
Signtologist
Yeah, I've mistakenly thought a 14'x98" print would look better with a horizontal seam. Only thing that could have made it worse was the fact that it was a cable bridge. Also to note, Arlon satin is nearly matte. 3m's satin is nearly gloss. There mattes and glosses are pretty well indistinguishable, but for whatever reason they thumbed their noses at each other when defining stain.
