Large Trailer Wrap Design Questions
Discussion in 'Designs & Layouts' started by mbarden, Jun 14, 2012.
  1. mbarden
    mbarden Active Member
    596
    1
    18
    Oct 1, 2006
    Iowa
    Hi Folks,
    I am designing a race traierl wrap for a 57' trailer. I have designed shorter trailers and installed a bunch of 53' trailers but have never designed on such a large scale. Does any one have any tips on how to set the file up? What scale shuld I use? What file type? Do I need to do it in sections? I am finding that Photoshop does not handle this size very well. I am currently designing at about 15" x 86" at 600 dpi. This will give me a final size of 10' x 57' at 72 dpi for printing. Even at that smaller size my .tif file is 1.5 GB in size. Any help would be appreciated.
    Thanks Folks
    Mike B
    Big River Sign Co.
  2. Mikeifg
    Mikeifg Active Member
    763
    Jun 6, 2007
    When we do them it's pretty much the same. But the ones we do are moving trlrs really tall. I believe our panel up to the drop deck came out to 127" +. The files do get big so the 1.5g is normal but blowing it up is another thing. Sometimes I try and simplify and work the file in sections. Maybe try that. Rasterize the whole thing @ full scale and see if you loose any quality if not your good to go.
  3. mbarden
    596
    1
    18
    Oct 1, 2006
    Iowa
    Thanks Mike
    MB
  4. Smacka
    Smacka Member
    165
    Sep 22, 2011
    Florida
    Well, we do them in vertical panels with a 1/2 - 1" overlap. Designing at 600 dpi scaled down is no different than working at 100% @ 72 dpi. The file size should be identical so what's the point. As far the artwork being 1.5 gig yes that is normal for raster images. Can you design it in Illy or Corel? That would certainly help.
  5. x2chris7x
    x2chris7x Active Member
    584
    5
    18
    Oct 30, 2008
    Louisiana
    If you can work with Smart Objects pasted from illustrator, then you can design at a proportionate size at a lower resolution, and when you ready to save out for print you can scale it to the size needed, and the artwork will be clean (If they are vector smart objects). Once you have it at actual size, flatten it, then split it into whatever panel size you need.
    Thats what I've always done... and it works for me. It takes a while to enlarge it, but oh well... I dont think there a way around that
  6. Circleville Signs
    Circleville Signs Very Active Member
    2,140
    11
    38
    Sep 30, 2009
    Circleville, OH
    This is why you design in vector.....
  7. Flame
    Flame Major Contributor
    8,283
    6
    38
    Apr 26, 2006
    Vancouver
    AMEN!!!! I couldn't imagine designing a wrap in photoshop. People seem to do it all the time, but gotta love when I can edit anything I want in a flash, have unlimited text options, and my final print file size is under 4mb. Vector ftw :corndog::corndog::corndog::corndog::corndog::corndog:
  8. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,763
    51
    48
    Feb 27, 2007
    World
    How would you design pictures into vectors, redraw them?
  9. Coloradosigns
    Coloradosigns Major Contributor
    7,929
    54
    48
    Sep 10, 2010
    Denver.
    i agree with everyone. Vector is the proper way.
  10. Coloradosigns
    7,929
    54
    48
    Sep 10, 2010
    Denver.
    you can place pictures in illustrator by the way.. as much as i really try to talk customers out of photographs on wraps..always tacky.
  11. Flame
    8,283
    6
    38
    Apr 26, 2006
    Vancouver
    Pictures on wraps... highly discouraged. But if you do, just lay them into your favorite vector program.
  12. 4R Graphics
    4R Graphics Active Member
    724
    I use vector and photoshop just depends on what i am doing. Mainly if customer demands photos I do it in photshop and bring in vector logos and what not as smart object.
    I always design at full scale in phtoshop. Illy well it depends on how big the job is I scale it until it fits on the artboard.
  13. Gino
    Gino Major Contributor
    30,482
    1,411
    113
    Jun 7, 2006
    PA
    You're not limited to just one program. You can do some portions in one, some in another and then combine them in still yet another.
    We try to do anything large in vector. Sometimes the guy that comes in and wants a picture of his dog on his magnetic, we'll just do it Photoshop just to make it faster and easier.
    Designing in Photoshop is a frickin' nightmare, but getting someone else's file in raster is just about the dumbest thing... especially when it's a large job.
  14. SightLine
    SightLine Very Active Member
    We do work with the on occasion in Photoshop as well. Of course vector is preferred but with some designs that is simply not possible. Does help having 64 bit Photoshop with dual quad core xeons, 32GB of ram, and a 256GB solid state drive though. Flys through even 6gb files with ease. Not bragging, just stating that given enough horsepower and the right components that working with massive files in Photoshop is really not tedious or probamatic.
  15. signswi
    signswi Very Active Member
    2,136
    1
    The proper way is the way that works for you to get the result you want.
    Stupidest debate ever. Use all the tools. I personally start with Illy but if I need to get into raster stuff I have no problem flipping into Photoshop, doing those elements, and then combing them all in InDesign for export. Raster data placed into Illustrator gets nasty as Illustrator is 32bit and only has proper color management if you are in a PDF workflow (i.e. if you ever save out to EPS...bye bye ICC data).
    As to the OP, 1.5GB on a tif isn't all that much. You shouldn't have any problem throwing around a file at those size/resolutions. Make sure you're using the 64bit version of PS and that GPU acceleration is turned on. Use .PSB while you're working and export to a zip compressed .TIF or PDF/X.
