Gennalee Thunder
Does anyone else that uses Laser Cut software ever have an error pop up that say communication broken for timeout close and open output window and retry?
Then after a few times getting that message it says motioncard softdog no same.
Everything was fine till we moved into the new side of our shop now getting these messages since, I've switched USB ports a million times checked connection on the machine, checked PC for updates (always the manufacturer suggestion) everything seems to be the exact same so I can't figure it out. I've googled it several times and read all the results that apply to it, so far nothing has worked.
Would appreciate any help!
