The correct tool for the job is one that makes you money.
Agreed
I wouldn't flatbed print on warped material that caused headstrikes and extra wear and tear on my machine because the customer wanted me to.
same here
Why cut something that corrodes your $40-75000 machine to do a one off? Even if it only takes 1% of your machines life away, that's still probably more than the job is worth.
if I cut Kydex on my laser it will NOT corrode my machine.
There is no way to neutralize vaporized acid. You can vent it outside, but by the time it's cuttings it's already damaging your machine.
why on Earth would you make such an obviously false statement? do YOU have a PhD in chemistry?
You can use a Toyota Camry to pull a 10 ft RV with a tow hook, sure it works... But the damage you do to your transmission isn't worth it, and you'll like do it up one hill then never be able to do it again. .
Agreed, but for a 1-off rescue and if you happen to have a bunch of snatch blocks and rope, the Camry would easily pull even a fully loaded semi--- without sustaining any damage.
The right took for the job, is a tool that doesn't break when doing the job. There's normal wear and tear.... And then there's causing unecessary damage to get the job done.
"tool"? well, this is also false as every tool will eventually wear out. As the owner of a tool it is up to you to decide what wear and tear you will allow on it.
It's like using your Olfa blade, chipping the. Rao out of it but managing to screw in a flathead screw....except it's a $40,000 okfa blade your destroying. Sure you can do it, but you'd have to be pretty dumb and not business smart to take the risk. I don't care if it's my best customer, I'd never do something that could potentially destroy my whole machine, even if it was a 5% chance.. .. it's just not worth it.
uh.... not really. Again, to me, neutralizing any aerosolized acid as well ad binding or neutralizing and toxic fumes is something that I would do. I can have a carbon filter and aerosolized buffer solution setup in less than an hour. so depending on what I was going to get in return, just cutting the Kydex would be my choice.
dude, there are way too many ways to put image on substrate to say one is right and one is wrong. I agree the normal user without having a chemistry background should not attempt to mess with dangerous chemical by-products by lasering the Kydex.
