Laser engraving question
Discussion in 'CNC Routing & Laser Cutting' started by Steve Middleton, Nov 1, 2018.
  1. Steve Middleton
    Steve Middleton New Member
    8
    1
    3
    Sep 9, 2018
    PA
    I've had my new laser less than 3 months and it's definitely been a sharp learning curve. Latest problem is PhotoGrav/Corel/RDWorks. I process a picture in PG, import to Corel, and save as dxf but RDW does not recognize the file..."no data". I've tried, I think, all the variables without success. I did a "wireframe" which did transfer and was a very garbled mess. Any input will be appreciated!
  2. timgo
    timgo Graphics Designer
    277
    15
    18
    Aug 20, 2016
    Delft
    You need iEngraveLab PhotoLaser plus.
    Try the Trial Version;
    https://updater.cadlink.com/CommercialReleases/trial/EL91_trial.exe
  3. Christian @ 2CT Media
    Christian @ 2CT Media Major Contributor
    4,654
    724
    113
    Jun 15, 2009
    Mesa, Arizona
    Save as a .ai file
  4. cwade440
    cwade440 Member
    43
    32
    18
    Jan 21, 2011
    rochester, ma
    The only info I can offer is that I have (a few times) sent an image from Flexi to PG, and then sent the saved PG image to the laser with no issues. Now I usually either send the file directly from Flexi to the laser (vector cutting and simple raster engraving). If it's a photo, I use Photoshop and seems to get better results than I do with PG.
  5. fixtureman
    fixtureman Member
    361
    19
    18
    May 16, 2012
    Medina Ohio
    You have to use import file into RD Works you can't just open it
  6. Steve Middleton
    8
    1
    3
    Sep 9, 2018
    PA
    I'll try that. Thanks!
  7. Ian Stewart-Koster
    Ian Stewart-Koster Active Member
    925
    21
    18
    Sep 27, 2003
    Qld, Australia
    If you have used PG to prepare and create a file, then save it as a BMP (eng) from P'grave.
    Then, you need only IMPORT the BMP straight into RDW, set the speed, lineshift & power, and engrave from there.
    No need for corel or dxf steps.
    We do it this way all the time.
    Alternately AI works well out of Corel, but not for the BMP.
  8. Steve Middleton
    8
    1
    3
    Sep 9, 2018
    PA
    Thanks to all! The learning curve is exactly what everyone described only add and old, tech challenged, dinosaur for good measure:)
  9. Gene@mpls
    Gene@mpls Very Active Member
    2,025
    107
    63
    Jun 17, 2003
    Blaine, Mn
  10. Steve Middleton
    8
    1
    3
    Sep 9, 2018
    PA
