Laser XY Axis not moving
Discussion in 'Dimensional Signs' started by Dermot, Feb 3, 2013.
  1. Dermot
    Dermot New Member
    4
    Dec 18, 2009
    Ireland
    [FONT=Verdana, Helvetica, sans-serif]My Alpha LE950 Laser carriage is not moving.
    Carriage moves manually with power off, when laser head is moved to the centre of the bed and the left or up arrow is pressed it says overstep area. Limit switches test is ok, Voltage test shows steppers are OK. Work area is correct
    On startup it beeps for about 10 sec. then later another beep like it's doing it's startup routine but the carriage does not move.
    Laser is not firing either, Preadjust or test is not working.
    Door sensor and water pump switch are working.
    Battery is now changed as it was not updating the clock ...but it made no difference.
    Any help appreciated
    [/FONT]
