bofferdahl
I have three Latex 360 printers. One of them is having issues drying the ink on heavy coverage prints. All settings and parameters are the same across all three devices - profiling, heat, optimizer. I cleaned the machine with the issue as the inside can build up with oily moisture. The printer still does not completely dry heavy coverage. We print primarily to adhesive backed vinyl - Ij180cv2-10 and similar materials. Drying is set at max temperature. It does the same thing on 8 pass, 10 pass and 12 pass printing.
The areas that are not dry are streaky and fade in and out on the drying. Should I assume it is the heating element? Is there a way to clean/check the heating element? Any other suggestions? I do not want to guess at parts as they are not cheap.
Thanks!
Thanks!
