Latex 570 PIP saturated / ink upgrade uninstall
Stripeline18
Hello, I am running into an issue with our 570. Firstly, the prints are pulling optimizer ink only from the intermediate tank, and not the 3.0L Tank. Both ink tanks were replaced and the problem has continued, they are under warranty, or were not too long ago.
There are no leaks behind either ink tank. I ran the diagnostic menu on 3.0L components and the purge test on the Optimizer Ink tank. The component check came back OK, and we did hear the OP Pump behind the 3.0L Tank working.
When I ran a purge of the optimizer ink, the display had some average and standard values, then the next screen said 'PIP Saturated, please replace and restart.'
Does anyone have past experience with replacing the PIPs? Does this seem like the next logical step?
From what I can tell B4H70-67137 seems to be the correct PIP part number for my printer.
Secondly, since my shop does not run a lot of prints, and my inks tend to expire way before I can ever use them, I was thinking of uninstalling the ink upgrade kit, and just running off the intermediate tanks, but HP seemed to discourage that when I called about the OP ink issues, saying I needed to purchase all new ink tanks and other items that I can not remember anymore. Does anyone have any experience uninstalling the large format ink tanks? Is it difficult and what parts would I need to replace?
Thank you for time and expertise,
Jake
ToTo
Professional Support
You will need a set of all ink cartridges, cause they are marked to be intermediate tanks and can’t be used ascink cartridges.
To replace the pip you need to take a picture of the sticker on the frame of the sensor. After installing go into diagnostic mode and enter the values in the sensor calibration. The part number is correct.
Stripeline18
Thank you, I did remove the large capacity ink tanks in the diagnostic menu, but then I did not have a new set of 775ml tanks to replace with, so I had to revert to normal again. I assume just putting in a whole set of new 775ml will allow us to continue printer after the 3.0l are uninstalled?
ToTo
Yes. For sure.
Hoze
Jake
I had a similar issue with mine, turned out to be the pump being a little bit clogged, i had to remove the ink from the box and squeeze it while doing a purge, not sure if that would help you in that scenario
