brycesteiner
Upfront: I own a Mutoh VJ 1324 Eco-Solvent
I was talking to my Fellers Rep the the other day and I was saying i was thinking of getting a UV printer because of scratch resistance compared to eco-solvent.
Basically his response was they're not that much better, they are expensive (starting $60k), it's not good for vehicle wraps because the ink is not as pliable and will crack. Not great for banners for same reason. They are good for metal/glass and 'stiff' substrate. Eco/solvents is the only ink that truly soaks in because it "melts" the plastic slightly. Then about latex it was it's okay and more pliable than UV but not much different because it doesn't soke in, it's faster at drying but can also peel off.
Can UV inks not be used for banners and vinyl, wraps etc?
Latex has issues like scratching too? Can Latex be used for metal and glass? I know Solvents never could.
I'm assuming that even if UV and Latex can be used for vinyl and wraps you would still laminate for a consistent smooth look and extra protection.
Thanks for your thoughts as I look for another machine.
