Need Help LED Power supply help
Discussion in 'LEDs and Neon' started by ONLINE SIGN GUY, Jan 19, 2017.
  1. ONLINE SIGN GUY
    ONLINE SIGN GUY Member
    198
    Nov 13, 2009
    CEDAR RAPIDS
    I am doing a inside sign that will be back lit by led lighting, the needed wattage is 54 watts but the distributor recommended 60 watts, we can not wire directly and need to use a battery pack, Im curious what options are either battery packs that run off of AA or 9 volt batteries or possible lithium or portable battery packs? What options do i have, I have researched online and cant find the right answers. Thank you in advance
  2. ThatGuy
    ThatGuy Member
    130
    24
    18
    Dec 6, 2016
    Hear nor There
    Google dc to ac inverter. You may be able to modify this. [h=1]NPower Pocket Power Inverter — 12 Volts, 60 Watts at Northern Tools[/h]
    [h=1][/h]
  3. Brian27
    Brian27 Member
    102
    Aug 31, 2015
    Denver
    54 watts is a huge demand. That would drain a 12ah motorcycle battery in about an hour. 9 volt batteries wouldn't last more than a minute if it even turned them on at all.
    12 (volts) x 54 (Watts) / 60 (minutes) = 10.8 That means it will completely drain a 10.8ah 12v battery in one hour. You need to hard wire it.
