Light Magenta out of registration on XC-540
Discussion in 'Roland' started by MarkT, Apr 23, 2010.
  1. MarkT
    MarkT New Member
    1
    I' m trying to solve light magenta being out of registration. So far I can get away, but it bother me a lot. I'm using Roland Soljet Pro III XC-540. It looks like my light magenta is out of registration (side to side). I did adjust misalignment in bidirectional printing but with no luck. On busy prints you can not tell it, but for example if printing blue type on white bkgd light magenta shows is out of registration. It looks like this happened after I moved printer to different location. Any suggestions, Thanks a lot
    Mark
  2. Ian Schofield
    Ian Schofield New Member
    10
    Mark did you figure out this problem?
    Mine is doing the same but with the Cyan. I've made the adjustments
    as well but its still doing it.
    Cheers
  3. DCaptDan
    DCaptDan New Member
    22
    If you can't fix the problem by making adjustments in user mode, you may have to make head adjustments in service mode. (Horizontal, bi-directional default, etc.) You need the service mode code to get to these adjustments. If your machine is still under warranty, contact your Roland service Dept.
